There are several types of PowerBook G4 Aluminum models.
886 Questions View all
PowerBook will not boot past gray screen - no logo.
I reset the pram, reset the PMU, cannot boot in single user mode, do not have reinstall disk.
I have scoured the internet to find several people having the same problem, and have never come across a resolution.
I believe it is some form of corrupted system files.
Guess I will buy the OSX disk and see if that does the trick- my last viable option.
Has anyone had this problem and actually resolved it?
Thank you,
CS
Score 1
Comments:
Have you changed any of your Ram?
by
Add a comment
Chosen Solution
Try starting up in Safe mode by holding down the Shift key. Get an original system disk from Apple for $15
Score 2
Add a comment
http://support.apple.com/kb/ht1533
There's a link to start-up combo keys.
You could always try TechTool Pro or Disc Warrior.
I am currently resolving an issue which is quite similar and so far it is looking good. iMac G5 runs so slow when boot from disc. But when the install is done I will find out it the format and install works. I will know in about 2-3 hours.
Score 1
Add a comment
Add your answer
sdgery34f34f will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,307
