Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Screen brightness resets after restart
I have a Galaxy Tab A 8.0 SM-T387 that has a brightness issue. After I start it up, the brightness is all the way down on the dimmest setting. I turn it up and it stays up, thankfully, but when I start it up again, the brightness is all the way back down again. Is there a way for me to force it to keep the brightness where I put it?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi,
After you have adjusted the brightness setting, re-start the tablet in safe mode and check if the setting is still correct.
If it is then a downloaded app may be the cause of the problem.
The trick is to find out which one is the culprit.
Score 2
Add a comment
Add your answer
godingservices will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,550
