Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
Did damage to the fingerprint reader break iPhone 8+ charging circuit?
My iPhone 8+ screen is cracked. It seems to have been struck at the left edge of the fingerprint reader. I want to fix the phone but am concerned about the reader being damaged as i understand a replaced reader will not read fingerprints again unless it is replaced by Apple. A key symptom is “The phone will not charge”. I plug in a cable but the screen stays blank. SO, what is the likely hood i can reuse the fingerprint reader when replacing the cracked screen?
Add a comment
1 Answer
Chosen Solution
Unless the home button has suffered physical damage from the drop it should still work fine. However to be 100% sure you will need your phone to boot.
 So you don’t really have any alternative but to replace the screen. If it still won’t boot you could check the battery and dock, other than that you will need it looked at by a repair shop.
Score 1
Add a comment
Add your answer
steve brown will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 72
