A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Stuck in Password Reset Loop
I’ve tried resetting the PRAM, going in safe mode, and booting to flash drive Mac OS installer to get access to terminal, disk utility but laptop always boots to the reset password screen. I did do options 2 & 3 in the password reset menu. It indicated reboot computer and normal login should work but it doesn’t.
Laptop works on external monitor only since laptop display is damaged and needs a replacement assembly part.
This might have to go to an Apple Store. I have no way to disable the auto boot feature.
Add a comment
1 Answer
You might be able to fix this on your own!
Heres the needed guide MacBook Pro 13" Function Keys 2017 Display Assembly Replacement
Add a comment
Add your answer
mcavil will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,144
