1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Doesn't load Startup Disk
Can I use A Hitachi Travelstar 2.5" Internal Hard Drive. It is 500 GB and 7200 rpm.My son and I put one in and I havn't been able to get it to load the install program. Your installation instructions wher great. Thanks Greg Haines
1 Comment
I can't get it to start up. It just keeps running the search circle
by
Add a comment
1 Answer
Chosen Solution
Has the drive ever been formated MS-DOS? If so you may never be able to use it in a Mac. If it is a new drive, it should work fine. Use disk utilities on your OS install and format, then partition it to 1 partition. You should then be able to install the system with no problems. Just hold down the "C" key when booting to get to the disk drive.
Score 3
Add a comment
Add your answer
Greg Haines will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 10
All Time: 1,016
