Late 2008 unibody Hard Drive Cable
Hi!
I have a late 2008 macbook 5,1, 13inch, 2.0 GhZ.
I made the HDD to SSD upgrade last year, worked fine.
Now, the folder+question mark is popping up when turning it on, and when going with option-key, no discs can be seen. Replaced hard-drives, nothing happened. So I´m betting on hard drive cable fail.
It has been pretty complicated to stumble upon such said cable for this model. From 2009 on there are plenty of offers….
So, will the hard drive cable for any other model do the deed? diff. year? diff. size?
I appreciate your comments on the matter, thanks for your time!
Update (10/24/2019)
So, @arbaman & @danj I have 4 external disks. Tried all with Option-Key at startup. This happened:
N1 the original, now external, nothing happens. (dead)
N2 is new, unformatted, SATA III, 2,5”, nothing happens (because it has no format?)
N3 is a Windows-formatted disk. Nothing happens.
N4 is an old, faulty mac-formatted disk. Gets recognized. Unfortunately it has no OSX bootable file.
Probably the reason is not the internal disk cable, but only the original disc (N1) being faulty.
N2 is supposed to be the replacement disk I bought but since it´s not recognised I supposed it should be the cable. Also, now I notice that it's a SATA III and not a SATA II (compatible?).
N3 I thought could appear if the mac was running ok internally?
I'll download OSX.dmg files on N4 and try to run it from there. If it works, I could run Disk Utility, format disk N2 if it's compatible and keep that as internal SSD unit.
Please comment your opinion. I feel like I'm trying to hit a pinata in a dark room here! Thanks again!
2 Comments
Who's SSD did you use? Make & Model.
by Dan
Hi Dan! I used a Mercury Electra 3G SSD by OWC. It worked perfectly for a year or so. The funny thing is that I get the same response (none at all) when starting and pression Option-Key as when I extract the hard-drive and run it externally. In both cases, Opt-key pressed I see nothing, just the mouse pointer. I´m not sure if it is the hard drive cable... any thoughts?
by jack kerou
