Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
Bootloop after lightning flex cable replacement on an iPhone 8
Hi! I recently replaced my friends iPhone 8 flex cable as the old one no longer worked, the battery still had some juice in it so i could boot. But after replacing the flex cable, it now boot loops. Disconnecting the connector makes the phone boot and connecting the old flex cable makes it boot as well. When the flex cable is connected and holding down the power button brings up nothing on the screen. I’ve already tried two new lighting connectors and they also don’t work. Everything is screwed in correctly and everything is plugged in.
Any help is appreciated :)
Add a comment
Most Helpful Answer
Are all the replacement lightning docks you’ve tried from the same supplier? - ie. could they all be faulty? I try to keep genuine spares of most common replacement parts for each model for testing.
Score 1
1 Comment:
Yeah they're from the same supplier. I could try getting a different one on eBay or something
by
Add a comment
have you resolved this?! having the same issue!
Add a comment
Add your answer
Ryley Windmill will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 113
