Toshiba TV no picture but still has sound
Hi there, I have searched through the previous questions and probably know the answer (T-Con Board) but just thought I’d check for opinions.
I have a two year old Toshiba TV 48U7653DB that looses picture a few minutes after turning on but still has sound.
I have tested with a torch and there is no picture/movement visible. I have also switched the tv off overnight and the problem still occurs
It is currently connected to a Virgin TiVo box only
If it is the T-Con Board is this something I can get and do myself and is it worth it etc?
Many thanks
1 Comment
T Con board generally an easy fix if you are reasonably handy. If you’ve never taken anything apart like this before my advice is keep it that way. There are some fiddly, easily damaged connectors on the T Con and if you are unfamiliar with them you risk causing more damage. Not to mention some nasty voltages in there so if you are not aware of what or what not to touch, drop it off at your local repair shop.
by Gary Cunningham
