Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
I cleaned my logic board with alcohol and now it won't turn on
Okay, so I fixed an ipod that had water damage and everything worked great except for the speakers/headphones, they would work sometimes and then shut off unless plugged into the computer, then they worked fine. So I opened it up and found corrosion around the speaker area, cleaned it all up with 70% isopropyl rubbing alcohol, put it back together doing a thorough check to make sure everything was connected, and now it won't power on or or connect to the computer.
I want to see if it's possible to fix so I won't have to buy a new logic board. Any help is greatly appreciated.
Thanks.
Add a comment
1 Answer
Chosen Solution
Kaiden, I'd go ahead and open the iPod once more. Use this Guide to deal with the damage. I would not just go and buy a new logic board. Try a new battery first. Good Luck
Score 1
Add a comment
Add your answer
Kaiden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 693
