Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Bright Spot On Inside of Screen
iMac 14,4 : 21.5 inch : mid-2014
Over the weekend I upgraded the HDD in my iMac to an SSD.
This requires removing the screen, which is glued onto the enclosure.
As part of the re-assembly process, I cleaned the old adhesive with 91% isopropyl alcohol, applied new adhesive strips (LeFix, not iFixIt, please forgive me), and put everything back together.
For 3 days, everything was fine.
This morning, there was an irregular spot on the inside of the upper-right corner of the screen. The spot is about 2 1/2 inches / 6 cm long x 2 inches / 5 cm high.
Although it is a bright gray, it is not visible against the dark background of my desktop picture. I only noticed it when I had a white browser window in the corner - because it's impossible to not notice. It's brighter than the picture below makes it appear to be.
The spot had not been there 1/2 hour earlier. I know this because every morning, I log into my parents' security camera system to take a screen shot and record the battery levels of the cameras; because Arlo does not provide any logging functionality. I always have the browser window in the upper-right corner of the screen, to include the clock display in the screen shot.
Does anybody have any idea what could be causing this?
Thanks.
Add a comment
1 Answer
Most Helpful Answer
Ouch! Looks like your cleaner creeped through the foam sealer between the cover glass and the LCD panel. Not much you can do here sorry ;-{
Maybe a bit of time will dry it out, hopefully not leaving a film deposit of the adhesive you where cleaning off (or is this the residue?) If it bothers you you’ll need to replace the screen.
Score 1
Add a comment
Add your answer
Mac Bob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 326
