Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Questions View all
iMac won't boot from SATA or USB (Can't find startup disk)
Hello,
My 2012 iMac Intel 27" EMC 2546 is not working correctly.
I purchased the SSD upgrade kit and I cannot get it to boot. Below are the symptoms:
  • iMac does not show any disk in Startup Manager (holding Option at startup)
  • In recovery mode, the SSD is visible, but is not recognized as a startup disk. Verifying the disk shows everything is ok.
  • If the iMac is turned on without pressing any keys, the flashing question mark folder appears
  • The SSD does not work internally (connected to the SATA cable) or externally (connected by USB in the enclosure).
  • The old HDD was wiped but also cannot be read from the SATA or USB connection
Here are the steps that I’ve taken to remedy so far, without any luck:
  • Checked to ensure that the SSD was properly formatted. I verified its functionality by externally booting on a 2012 MBP and a 2012 iMac 21”. Everything is working correctly (running Mojave). Additionally, the enclosure and temp sensor are working correctly.
  • PRAM reset multiple times. Additionally, removed some RAM and changed the slots, and then went through the PRAM reset again.
  • SMC reset
  • Internet recovery through startup manager
This iMac was donated to me from work and was wiped before being given to me. Could this be a culprit?
My only other thought was the SATA cable to the board, but I’m not sure why it wouldn’t boot via USB.
Any help is much appreciated. Thanks!
Update (10/12/2019)
An update to this:
I purchased a SATA cable and when through the SATA Cable replacement guide here on ifixit. Everything has gone smoothly, but I still have this issue persisting.
Just to recap:
  • I have a new 2.5” SSD purchased from ifixit that is formatted correctly and has Mojave installed on it. This SSD is 100% working correctly as I’ve been using it with another 2012 iMac (through USB). I have ruled out the SSD as the culprit
  • I have a new SATA cable installed into the iMAC, but the same symptoms persist
  • The iMac powers up, but will show the flashing question mark folder (this is with the SSD plugged in internally to the SATA cable)
  • In recovery mode it does not detect the disk
  • In disk select (pressing option on startup) it only shows ‘internet recovery’
  • The mac was wiped before it was given to me; could this be the culprit?
Thanks in advance.
Add a comment
Most Helpful Answer
On an external drive, any format will work. But internally it must be APSF or GUID to be seen.
Is this a blade drive or a 2.5” drive? Can you give us a link to what you bought.
Score 3
7 Comments:
Hi Mayer,
The format for the drive is shows as APFS in disk utility, and I originally formatted it as GUID MAC OS Extended Journaled.
The SSD is 2.5" drive from the ifixit imac SSD kit (Crucial MX500 SSD). I can confirm that the SSD and enclosure are all operating perfectly. As I mentioned, I tested it on a 2012 MBP (through USB), and it's currently plugged into a 21" 2012 iMac right now and operating correctly.
I believe this seems to be an issue with the 27" iMac and not the drive, but I'm not sure what.
by
Try Target Mode. Use a firewire 800 cable hooked to each. boot the MBP, then boot the iMac holding down the T key. If all is OK the new drive should show up on the desktop of the MBP. If so you can now install a system to it from your MBP if you have one downloaded.
by
Hi Mayer,
putting it in target mode did not work. There is no disk visible on iMac when I tired the SSD in USB or SATA.
by
Please see my update from 10/12/2019. Unfortunately the problem still persists
by
Will the machine boot from the new SSD when using it externally with a USB to SATA adapter?
by
Show 2 more comments
Add a comment
On a boot up hold cmd R
Go into utility next go to disk utility select erase them format. It should now come up in the system.
Add a comment
Add your answer
Maverick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 435
