Fix Your Stuff
Right to Repair
Store
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
521 Questions View all
Computer freezes with display replacement [updated]
Update 3
We put the old display back in the machine and it no longer freezes at all. So I don’t really understand this issue. What would cause a MacBook to freeze randomly with a replacement LCD (Apple OEM part of course), but not in safe mode? And somewhat intermittently?
— Old issue:
We recently replaced the display on this MacBook. After installing the replacement, when we screw the bottom casing back on and use the computer, the entire system freezes (display stays on, nothing moves, won’t go to sleep).
However, if we leave the two screws in the top corners of the bottom casing out of the machine, it works perfectly. Also, it works perfectly in safe mode regardless of whether the two screws are installed or not.
The screws in the corners are the correct length. An SMC reset and NVRAM reset didn’t affect anything. I can’t for the life of me understand why those two screws would have anything to do with it, is it just coincidental or is something going on?
Update: So perhaps the screws were just coincidental. We just booted it up with the bottom casing on but not screwed in, and it still froze after around a minute. We are going to reinstall the operating system and see if that helps at all. Intermittent problems are the worst :)
Update 2: Disabling login items and reinstalling the OS (on top of the existing install) didn’t help. If we don’t boot in safe mode it freezes a minute or so after boot regardless of whether we login or not anyways.
Add a comment
The Essential Toolkit
The most helpful tools in our most compact kit.
Shop Now
Shop Now
1 Answer
Check your logic board screws you may have installed a long screw where a short one is required. Check the screws as listed in MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement in Steps 14 & 31 getting mixed up.
Comments:
All those screws are as they should be. She wouldn't have removed those components to do a display replacement anyhow.
by
Someone else could have ;-}
Any dents in the cover? Is the case warped at all?
by
@danj Aha true true, although it wasn't happening before this replacement. No dents or warps in the cover or casing, it fits on normally.
by
mmm... sounds like the display assembly has an issue. Lets try this carefully plug in the iSight cable from the new display in with the original display still connected via the LVDS. Is the system stable that way?
by
Add a comment
Add your answer
Jonah Aragon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 33
