stuck on press home to upgrade
Hi, My touch ID and home button had been broke a while, ''''this was making my battery drain really quickly, i read online if you factory reset the device you can set up without touch ID and this can help the battery problem, But since doing this i set up the phone, connected to WiFi, and began to put my data from iCloud on, Because I did not use touvh ID i had to set up a passcode, I then was brought to a screen saying ‘press home to upgrade’ it shows the assistive touch button is on the side of the screen but I cannot use it, its as though it is frozen, I plugged into itunes and i cannot connect as it says enter passcode to use iphone but there is no way I can do this, I am just stuck at this screen:( PLEASE HELP
