Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
No camera functions working
So my colleague replaced the back cover and screen for an iPhone X. By replacing the back cover i mean that we bought a new frame with the back cover already in place. After the replacement the main camera no longer works and the front camera only works sometimes.
I have tried the following:
- Replaced the main camera.
- Replaced the front camera.
- Replaced the flash and on/off button cable.
- Replaced the bluetooth antenna cable.
- Checked all the connectors on the main board and all look fine.
- Did a full reset of the phone 2 times.
All this and nothing worked. I tried turning on the flashlight as well but nothing happened. Any idea what it could be and what to try next?
Add a comment
Most Helpful Answer
I’ve seen this a couple times on an iPhone X, and it seems to be a board defect. When you say you tested the board connectors, did you test voltage on the pins specifically?
Score 1
1 Comment:
Thank you for your answer.
So if it's a board defect it means my colleague didn't cause it and it was a coincidence? I mean it's not exactly easy to damage the board by removing it from the case. The iPhone X board don't really have a lot of exposed components.
Never said i testet the board, i just visually checked the connectors. Maybe i should have been more clear about what i meant. Whats the best way to test the voltage? Is there a tool i can use or a multimeter will do?
by
Add a comment
Try to put it back in the original back case and when it works you know it is a fault in back case that you bought.
1 Comment:
Already have. Same result unfortunately.
by
Add a comment
Add your answer
Total Repairs AS will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 3
All Time: 57
