Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Will this solution work?
Hello, I need an answer to my question (please and thank you.)
Ok, so my phone fell and cracked, the screen turned black. However, I am able to receive messages, calls, etc. But I can’t see anything because the screen is black. I want to buy the ifixit Galaxy s6 screen replacement kit, is this the solution?
Add a comment
1 Answer
Hi @sarahmed617
Based on your question I believe the screen replacement will fix your phone completely. Because of how the phone is constructed, I highly recommend you get the replacement charging port flex cable with your replacement screen. The light keys on either side of the home button are attached to this charging port and are easily damaged during the screen replacement process. It is also a good time to replace the charging port as it is a very difficult repair if you are not replacing the screen (preventative maintenance).
Here is the part and tool kit
and you will need to pick the correct charging port based on your specific model number here
Repair Instructions can be found here
Best of luck!
Replace a screen compatible with the Samsung Galaxy S6 smartphone. 5.1 inch AMOLED 2560 x 1440 Display. Image
Product
Galaxy S6 Screen
$92.99
Add a comment
Add your answer
Sarah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
