A simple and cheap laptop by Lenovo. This laptop can be seen in many K-12 classrooms.
Need help Unmanaging a chromebook
I bought a used chromebook off eBay and it is enrolled in some school thing i tryed to access dev mode by removing battery and plugging ac cord in multiple times but it still says admin blocked. And I don’t know if theres anyway to reset the bios can any of you help me
Score 2
Add a comment
1 Answer
To Wipe your Chromebook follow these steps
  1. Turn off the Chromebook.
  2. Press Esc++Power.
A yellow exclamation point (!) or "Please insert a recovery USB stick" is displayed.
  1. Press Ctrl+D to begin Developer mode, then press Enter.
  2. Press Space, then press Enter.
The Chromebook deletes its local data, returning to its initial state. This can take approximately 40 minutes.
Note: ​If Forced re-enrollment is enabled for the device, you'll see a note that Developer mode is blocked. This shortens the wipe process, and still allows for re-enrollment when the device automatically restarts in Verified mode.
  1. When the transition completes, press the space bar, then press Enter to return to Verified mode.
  2. Enroll the Chromebook before signing in to it.
2 Comments:
That’s the problem I’m trying to change the forced enrollment by changing the rw_vpd in dev mode but it’s blocked so what can I do
by
Have the same problem, bought a set on bankruptcy auction. They are locked and the old company is no more. 😟
by
Add a comment
Add your answer
Caleb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 968
