My ice maker won't fill with water
Ice maker does not fill with water. Changed water inlet valve and replaced ice maker. Still nothing. Shut off arm stuck in off position. Not frozen wàter line. Changed filter.What else could it be? Kenmore side by side indoor içe maker 106.5113
Add a comment
1 Answer
Most Helpful Answer
Sounds like it’s the shutoff arm. The last time I replaced my ice maker I didn’t install the arm correctly, and got it stuck in the off position. Once I fixed that, no problem. If I recall correctly there’s a little notch on the arm which needs to fit into a small slot on the ice maker’s on/off valve.
Score 1
Add a comment
Add your answer
PAMELA ACORD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 384
