This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
No Power At All
Hi, I have a Nintendo DS Lite that won't power up nor indicate when charger is plugged in to be charging or that it recognizes that the charger is plugged in. Help any suggestions on what to change? Maybe the battery? I realized the other guys here who had the same problem at least got some sort of light when charger was plugged in, but I got none at all.
Score -1
1 Comment
Thanks alot i will give that a those options a try.
by
Add a comment
1 Answer
Chosen Solution
Make sure that your charger works. Get a multimeter and check it out. Check your battery with a multimeter and make sure it is at holding some kind of charge. Take a look at all the connections from the battery and the AC charger. Make sure they are not bend, broken or corroded. Check the F1 and F2 Fuses. Here is a video that can help you with the repair. The fuses are available here, as a set. for any further teardown and guides check here. good Luck and let us know if this helps.
Score 2
Add a comment
Add your answer
Corderro Lightbourne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,411
