Guides and support for various television (TV) brands and styles.
Sharp TV blown fuse?
My Sharp LC-32SH130K blew when it was turned on. There’s been no problems with it before but now no power light shows and it won’t turn on. I’ve attached pictures of each of the boards. Is it easy to repair the fault or is it finished?
Update (07/28/2019)
Add a comment
1 Answer
Most Helpful Answer
@brokentv123 you’ll have to do some troubleshooting to determine what has failed. Get a multimeter and check the power coming to the power board. AC voltages so be careful. then measure the DC voltages on the connector going to the main board. See what standby voltages you have. Most common boards to go are the power board and the main board. Not a difficult repair but you always want to check things out so you get the right board.
Score 2
Add a comment
Add your answer
Sophie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,631
