Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Not charging even with new battery
Hi
A few weeks ago I dropped my iphone 6s in the water, it all worked fine could charge and so. Until a few hours later I couldn’t charge anymore so I thought the battery was dead. I checked this theory by using a volt meter and the pins connected to the battery gave out a good voltage when connected to the power outlet. So I bought a new battery and just replaced the old one. My iphone got back to life however it still won’t charge ?!? even tough the pins gave out a good voltage. Any thing I can try or should I just give up ?
thx
Add a comment
Chosen Solution
I think you have done all you can for a water damaged phone unless you want to try a new dock connector. Your phones charging circuit on the logic board will be the problem for now, and then other problems will arise. I would not spend any more time or money on this device.
Score 2
1 Comment:
yea I guessed so, its just wierd it gives the charging symbol and I get a voltage but it doesn't charge :-(
by
Add a comment
Have you tried cleaning the the charge hole? I found there gets a lot of dust and crap in a tiny space and the wire won’t connect! Use a needle and try digging around, you’d be surprised
Score 1
1 Comment:
I have, maybe will try to do it again, however it shows the symbol of charging on the phone and the pins give voltage so I don't think thats the problem ? because ig gives power
by
Add a comment
Add your answer
Goldppl will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 52
