Repair information for standalone freezers.
192 Questions View all
Why is my freezer not freezing continuously?
I have a GE profile fridge with French doors up top and the bottom freezer. Model # PFE28KSKSS
we first noticed items added to the freezer not freezing and the ice makers ( both in freezer and in fridge door) stopped making ice. There was ice at the bottom of freezer under the compartments. We broke that ice out and left the other, still frozen foods back inside. The next day those items had started defrosting. It seems to be very cold at the bottom and not circulating through the entire freezer. The next night everything was froze as should be and it seemed to be running fine. When I got up today, food was defrosting again. What can cause it to stop, start, and then fail again?
1 Comment
Tony!! Thank you so much, I’m flailing here trying to save my food and freezer. I had tried to copy the model number from the Lowe’s website, which was completely different from the one inside the fridge.
Model # GFE28HMHEES
by
Add a comment
1 Answer
Chosen Solution
Ice in the bottom of the freezer is indicative of a frozen or obstructed defrost drain tube. Some models have a heater for this aspect. The drain tube needs to be cleared of ice or other obstruction in order for defrost water to be drained properly.
Please recheck the model number provided. I think it's missing one character. As is, can't reference service information specific to your model.
Update (07/15/2019)
Basically, Kristen, the way it works goes like this:
The control board governs cycles of freezing and defrosting in the freezer compartment. It receives input from thermistors (monitoring temperatures in the freezer) to interrupt cooling, and initiate defrost cycles when the low temperature set point is reached. Power is then sent to a heater element so that it can melt away any frost or icy build up on the evaporator coils (this is where the water you found frozen at the bottom comes from). A thermometer detecting the temperature during this phase shuts off the power to the element when it’s high temperature set point is reached, ending the defrost heating. Again, the control board receives the input from a thermistor indicating the end of the defrost cycle, and the control board signals the compressor to restart and begin another cooling period. During the cooling period, there’s a motor and fan in the freezer (evaporator fan motor) that works to circulate the cold air.
If any of these components fail there will be problems. All your thermistor and thermostats, the defrost heater, etc., might be fine, and the control board could be the problem. But, considering your description of the problem(s), I might suspect a faulty thermistor, as these failures are common, and when they occur one might expect inconsistent performance (one time the cycles are fine, the next time something fails). Also, can’t rule out a possible evaporator fan motor failure, either, at this point.
You have to access the evaporator area of the freezer compartment in order to begin testing these components, and you need to be able to use a multi-meter to check components for continuity. Hopefully there’s someone in your orbit who is qualified to safely take a look and run a few tests for you. If not, you really need to call a qualified repair service.
Hope this might help you at least have a better idea of what might be happening.
Good luck, and keep us posted.
Score 3
Add a comment
Add your answer
Kristen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 38
All Time: 3,153
