Short on PP1V1 and PP2V8 not turning on
Hello, I have a water damaged iPhone XS max, it was ultrasonically cleaned but a short was found on PP1V1 and PP1V8, I removed most of the capacitors on that line but the short is still there, could it be a possible CPU short problem ?
What should I try next?
7 Comments
Need more info. What are the readings you are getting on these lines? Is the short on the top half of the board or the bottom half?
by Chris Stables
upper layer, where the cpu is situated
by Francesco
Have you removed the two audio ic”s U4902 and U5002 yet? They would be the first things I would remove.
by Chris Stables
no, will try, thx so much, which one of those 2 lines is connected to the audio ic?
by Francesco
@imicrosoldering hello, IC U4700 was found to be shorted, could removing that fix also the short on PP1V1?
by Francesco
Show 2 more comments
