Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Display issue and random boot loop
Hello all,
I was given a retina MBP, because of an issue. It’s in decent shape and actually works some of the time. I’m attaching a photo of the screen I see, just before it powers itself off. It will then sometimes go into a boot loop. If anyone has seen this before, or has an idea where I should start troubleshooting please let me know. Resetting the SMC and/or the NVRAM has absolutely no effect on the issue.
Add a comment
1 Answer
Chosen Solution
Ouch! This is a tricky one!
The logic board has a problem, the question is if its repairable or will you need to replace it.
As you state it works sometimes then you might only need to find the cold solder joint(s) it has and after fixing that you may be good. You’ll need to remove the logic board and do a good inspection looking for any liquid damage and/or corrosion as well as check the solder joints.
Do you have the needed skills and tools to do this? If not you might want to find someone locally or just replace the logic board which is not overly expensive given the fact you got the system for free ;-}
Right now iFixit has a 8 GB board MacBook Pro 13" Retina (Mid 2014) 2.8 GHz Logic Board You might find the 2.6 GHz Logic Board for less. If you can I would try to get the 16 GB if you plan on keeping it for a few years as it would be a better investment.
In anywise heres the guide to replace it MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
Replace a 2.8 GHz logic board (motherboard) compatible with the Mid 2014 MacBook Pro 13" laptop. Includes 8 or 16 GB of RAM. Fix processing issues like unexpected shutdowns, reboots or water damage. Image
Product
$179.99
Score 1
Add a comment
Add your answer
Gary Jenkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 86
