The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
My phone turn of and restarting when I try to install system update
my phone restarting and not responding , when i disconnected the power key restarting stop and when i try to connect again power key restarting again , i downloaded new updated operation system but when i try to install it the phone turn of, how can i fix this problem?
Add a comment
1 Answer
Most Helpful Answer
Have you tried applying update with and without charger plugged in while battery is near full?
I’ve seen that sometimes it gets stuck on the htc phone icon with the red exclamation mark if the charger is plugged in on certain htc phones for software updates.
Sounds like a bad battery if it switches off immediately when charging cable is unplugged.
HTC One Battery Replacement
HTC One (M7) Battery
Replace a BN07100 model battery compatible with HTC One M7 smartphones. 2300 mAh. 8.74 Watt Hours (Wh). 3.8 Volts (V). Image
Product
$6.99
Score 1
Add a comment
Add your answer
Abdalrhman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 216
