Clutch not fully releasing
Just replace clutch in truck no clutch pedal goes to floor without fully engaging need to adjust or bleed system. How to bleed clutch. How to adjust.
BLEEDING CLUTCH SYSTEM
1. Clean and remove reservoir cap. Top-off reservoir with NEW DOT 3 brake fluid.
2. Have an assistant depress and hold clutch pedal. Open bleed screw located on left side of transmission to
expel air. Close bleed screw and release clutch pedal.
NOTE: DO NOT reuse fluid that has been bled from system.
3. Repeat procedure until all air is out of system. Check and refill reservoir as needed during bleeding. After bleeding, pump clutch pedal several times. If clutch engagement is not satisfactory, repeat bleeding procedure.
4. If normal bleeding procedure is unsuccessful, perform the following:
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 423
4 Comments
@mnorton196969 what is the exact model and year for your truck?
by oldturkey03
1995 C 1500 Silverado 2 wheel drive 5 speed manual 350 V8
by Mitchell Norton
When you press the pedal it engages the clutch but not until your foot is almost on the floor
by Mitchell Norton
@mnorton196969 bleeding that clutch sounds about right.
by oldturkey03
