The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 Questions View all
S7 edge has service after repair, cannot make or receive calls.
Hello, I just replaced the screen (and frame assembly) of this s7 egde, and everything seems to be working fine, however, I cannot make or receive calls. When I try to call, the phone app shows dialing for a second and then shuts off, and when I try to call the phone, it goes straight to voicemail. I do however get LTE data and can send out and receive text messages, oddly. Any help would be much appreciated. Thank you.
1 Comment:
Did you replace the screen lcd that comes with the mid frame or did you buy them separately? I am in the process of doing a replacement of the whole phone, and noticed that the new mid frame seems to be missing the tiny square contact points that coincides with the motherboard. The old one has them.
by
Add a comment
1 Answer
there are couple of reasons for this. one might be your antenna cables are not on properly. the signal antenna is connects from your SUB PBA (daughter board) to your main PBA board. another problem which I think might apply to you if you changed the frame to a new one is that the frame has RF(radio frequency) issues. you would have to replace the frame. when getting a new frame, it is best to get a refurbished OEM frame than getting a copy one as you won’t be able to find OEM brand new frame in the market.
Add a comment
Add your answer
Armen Orbelyan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 164
