Any small, single-cylinder carbureted gasoline engine, usually used for lawnmowers. The engine used to create these guides is a Briggs and Stratton 300e series engine.
20 Questions View all
My Craftsman ys 4500 20 hp cranks but wont start even with start fluid
I accidentally ran over a chunk of wood and the mower shut down so I figured I sheared the flywheel key and replaced it and the spark plug with no luck I also sprayed starting fluid into the air filter after taking the filter out and nothing happened it just cranks over very fast but won’t start PLEASE HELP !!
Add a comment
1 Answer
Most Helpful Answer
Lou C This “I also sprayed starting fluid into the air filter” points to your mower not having a spark. Check on that first. If so, you do want to let us know what the exact make and model number for your mowers engine is.
Score 1
Add a comment
Add your answer
Lou C will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 190
