Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
Epson L360 Paper Jam
How to remove the small paper that stock inside the printer?
We don’t see the paper. Please Help Us!
Score 9
5 Comments
orastanley2235 are you sure there is a paper jam? Can you see anything from the paper?
by
I buy epson l 850 but when i want to print or any document it display close the scanner unit. How can i do to solve this
by
my printer is very good but not taking paper
by
How to remove stacked portion of paper in L360 epson printer?
by
Add a comment
Chosen Solution
orastanley2235  If there is truly a paper jam, try to find out where it is and clear it. If there is not but your printer signals a false jam error then the most common issues are:
A. A dirty printhead rail. It is either ink residue or dry. You can clean those gently with some lukewarm water and a rag
B. Paper pick up roller(s) that are not picking up. Clean the rollers with a damp cloth
If you need to disassemble or dig deeper into this, you can download the service manual from places like this
Score 2
Add a comment
  • Power down your computer immediately upon finding the jam.
  • Press the Paper icon button to eject the paper jammed within the Epson XP 434 Setup printer.
  • Pull open the printer’s lid and remove the paper stuck inside.
  • Search for small torn pieces and then dispose of them as well.
  • Make sure to use only smooth and straight paper in the printer.
  • Check if the printer is in a tilted position and change its location to a flat surface.
  • See if the removed paper is still usable. i.e., not creased or wrinkled.
  • Load them back into the feeder and start printing. Or feed a new stack of paper.
Score 1
Add a comment
Add your answer
orastanley2235 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 67
All Time: 11,027
