When using USB port my iQon laptop freezes
As soon as i plug something into the USB Port the laptop freezes
OS is Windows XP
and no upgrades
I find that when i use A memory stick there is a low noise like grrrr
then it will freeze like a power loss
Have you tried to go to control panel> system>device manager>hardware and checked to see if the USB port shows up? Try to uninstall it and restart your computer and see if it reinstalls it. Does it happen with Anything you plug into the USB or just a memory stick? Have you tried to use a different one?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 447
3 Comments
Werner what OS are you using? Did you recently have an upgrade or a new device installed?
by oldturkey03
Thanks for that.
I have done that allready still the same the mouse work on the USB
but the stick and external hdrive it stalls
by Werner
i am sure its the mobo there is a power losswhen using the memory stick or ext hdrive
by Werner
