The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Keyboard and Trackpad doesn't work since I replaced the battery
Hello,
Since I’ve replaced the battery by a new one, both trackpad and keyboard doesn’t work. I tried without battery and with my old battery but I got the same issue. So I bought a new trackpad cable and the trackpad and keyboard are still inoperative..
I can use the mac just with a extern mouse and keyboard. I’ve tried SMC, PRAM, delite .plist and nothing work.
Thanks for your help
Add a comment
Chosen Solution
I would replace the Retina MacBook Pro 13" Trackpad Flex Cable cable which is a common failure on this series. The symptoms you describe where both the keyboard & trackpad are not working centers around either the cable or the trackpad as its the common points for this problem.
Score 2
7 Comments:
I've already replaced this cable unfortunately… I ordered a other one in case of the first is broken.
by
OK, Good! So your MacBook Pro 13" Retina (Early 2015) Trackpad needs replacing. The trackpad in this series is a junction point for the keyboard so when both fail its either the cable or the trackpad its self.
Look at the pins to see if you see corrosion or bent pin.
by
The trackpad looks good, it can't be a software issue ?
This trackpad is good : https://www.ebay.com.au/itm/Genuine-Trac...
by
Run diagnostics if you can. Restart the system press the ‘’’D’’’ key. Any errors?
I can’t see this as a software issue. It’s always hardware from all of the systems I’ve done.
by
No error found during the diagnostic. So it's necessarily the trackpad ?
There is no trackpad available in the ifixit store (Australia), the trackpad that I mentioned is good ?
Thanks fo your help
by
Show 2 more comments
Add a comment
Most Helpful Answer
Check for any dislodged / missing components near the edges of the main logic board where you may have possibly used a pry card around those areas as that’s the only other thing I can think of that’s causing the keyboard and trackpad to stop working.
Score 3
1 Comment:
I've checked and nothing was dislodged.
by
Add a comment
Add your answer
pierrebouaye44 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 242
