Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
Motherboard screw holder came off causing issues
The iPhone X was working fine until the bottom right screw holder of the motherboard came off. Since then, the ear speaker, main speaker, mic isn’t working and the phone is dead slow. Can I use jump wire to remedy this? I can’t see anything connected through my bare eyes.
Please help.
Add a comment
1 Answer
Chosen Solution
Apple does have a tendency to route traces around screw holes…but not in this particular instance. That said, there are a lot of very fine traces in close proximity to the screw hole so if any one of those is compromised, then you will have issues with your logic board.
Each colour represents a different internal layer of the PCB. You will not be able to see these with your naked eye when looking “from the side”, only when looking at traces from a top perspective. I would take a closer look with a microscope to see if any the adjacent traces are visible, otherwise, you will probably not be able to repair this logic board.
Score 2
Add a comment
Add your answer
bijaya.pun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 140
