Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My iPhone screen is dark but work by seeing under a bright light
While I was uploading 3 of the apps at the same time, the screen went black . My phone screen is dark and the only way I can see anything is with a flashlight. Battery life is good. The touch is working. I can answer calls and do everything I normally do on my phone as long as I'm using a flashlight to brighten the screen. Even I can check my emails, can took pictures, can reset everything in the phone by using a strong flash light. The phone is in perfect condition, there's absolutely no physical damage to it and I have never dropped it in water. I have dropped the phone here and there but always with a case on it so there has never been any physical damage. I did the hard reset, factory reset nothing working to get back the bright screen. So far my phone is working normal, only the back light seems to be gone.
Does the LCD screen replacement will solve the problem?
Or
Is it a problem with motherboard so, I may not able to recover normal bright screen of the phone even replacing the LCD screen?
Thanks a lot in advance.
Add a comment
Chosen Solution
—-NO
—-YES
Score 1
1 Comment:
Thanks a lot for being specific.
by
Add a comment
Most Helpful Answer
If it's happened out of the blue with no previous damage it would most likely be the backlight circuit, or some part of it. This isn't really a DIY repair, u will need someone who can microsolder and is capable of repairing the backlight for u a good repairer would obviously try a working screen for u first before doing any work to rule out the screen
Score 2
2 Comments:
Thank you so much for the details.
by
It's really helpful!
by
Add a comment
Add your answer
Nelufa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 664
