Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
45 Questions View all
Is it difficult to change the charging port?
So i have to hold the cable in a specific angle for the laptop to load. Should mean, that the charging port needs an exchange. Not i dont have any special equipment apart from screwdrivers. Is it difficult to exchange that part?
Add a comment
1 Answer
First you should try using a different charger. If that doesn’t work then you should go ahead and change the charging port. Its shouldn’t be a hard job it just takes patients and time.
2 Comments:
do you think the charger may cause the problem? If it were the issue, then shouldnt it either be working or not working, regardless of wether i have to permanently keep it pushed to the top side of the charge port
by
No it can be a loos wire in the charger. But there is still a chance that it's the charging port. I recommend you first buy a charger with returns just in case.
by
Add a comment
Add your answer
dj-paok will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 117
