A singing, dancing, pink pony that responds to its included toys and outside stimulus.
4 Questions View all
Head/neck very loose and clicking
When I turn it on some of the moves it tries to do it clicks. Not positive what’s wrong but when it’s turned off the head and neck move around so I believe it’s either spring or motor there. I see the information for replacing motors or springs in legs but I believe it’s the head/neck. And where do I get the parts from to replace them??
Score 3
Add a comment
1 Answer
Most Helpful Answer
Upon dissembling the toy, I found one of the reasons why the neck clicks. there is a small plastic tab on the tip of the black neck coupler.
this slides into the potentiometer located in the white base of the neck
. This controls the rotation of the neck and prevents it from clicking. It got broken off. I got lucky and found the broken tab when I took apart the toy and managed to glue it back it on. I don’t know if the glue will hold. If it does not I will try and scan the base and see if I can 3d print it. I will make the .STL file available if need be.
Score 2
Add a comment
Add your answer
Jessica Hummell will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 20
All Time: 398
