Repair guides for the MacBook.
3788 Questions View all
Why won't my laptop turn on?
I have a macbook that I didnt have a charger for, for about 5 months. The last time I did use it, it worked fine. However recently I finally got a new charger and fully charged the battery and my macbook wont even turn on at all? Can anyone tell me why and how to fix the problem? Thanks
Add a comment
1 Answer
Chosen Solution
Resetting PRAM and NVRAM
Shut down the computer.
Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
Turn on the computer.
Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the second time.
Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
n some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step.
Force Quit (Option-Command-Escape)
Restart (Control-Command-Power)
Force Shut Down (press the power button for 10 seconds)
Score 4
Add a comment
Add your answer
jholeen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,148
