Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
iPhone X Bootloop earpiece flex cable issue 4013
I had the same issue as described in the thread I will link below.
iPhone X in bootloop, error code 4013 in iTunes and nothing would help to restore EXCEPT disconnecting the earpiece flex cable. I disconnected it and the phone booted up. However, when I reconnect the flex cable, the phone will not boot up anymore.
Any suggestions?
IF I connect the earpiece to the logicboard AFTER the phone is booted up, the phone continues to work and the earpiece works too. Face ID doesn’t. It doesn’t shut down automaticly or anything. Did anyone have this issue before?
iPhone X Error 4013
Score 1
1 Comment
An update: I bought a new earpiece flex module, with the sensors and it seems to boot up with that one connected. SO what can I do now to replace, and have faceID still working?
by
Add a comment
1 Answer
Chosen Solution
The iPhone X logic board is very susceptible to damage following a drop due to it’s sandwiched, dual circuit board design. Some cracked solder balls along the terminations can cause Error 4013. That’s not to say this is your specific issue but if modular or software approaches don’t solve the problem, the next step is to have it looked at by an experienced micro-solderer.
Score 1
2 Comments:
Thank you for your reply. I was afraid that I would need the help of a micro-solderer too. The only thing that I find so weird is that my iphone is working perfectly after reconnecting the earpiece to the logicboard after the phone booted up.
by
Hi
i have exactly the same issue.Since i open the phone and i put the cable of eearpiece, the phone does not loop.Did you find any soltuion in this matter?
by
Add a comment
Add your answer
Kelvin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,388
