4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Power Button didn't work (new case)
Hello together,
the case of my SE was broken, so I brought a new one and transferred everything in it.
After the first test I noticed that the power switch didn’t work. so I found out that the new button was different. In the picture you can see that the pin on the right side is missing and in the old case there was a cable.
I tried to install the cable in the new case but it didn’t seem right and also didn’t work.
Thanks for your help!!
Add a comment
1 Answer
U can remove the pin using some thin pliers or something similar grab it in the middle and try to pull it up and out of that hole then push it into the new housing, the cable pictured I think is for grounding for the antenna or something like that, that wont affect the power button… the power button itself the flex could be damaged and in the picture it doesn't really look plugged in fully…
Add a comment
Add your answer
troche turnout will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 171
