Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
My iPhone doesnt read touch after fixing the screen
I fix my iphone screen and now it doesn't read touch. Is there something I forget to hook up inside?
1 Comment
You're connection is probably just loose. Look inside again to see if it is, or if there is any damage to the cable. Sometimes the connector can be a bit misleading especially if it has that QR looking sticker on it.
by
Add a comment
1 Answer
Chosen Solution
Make sure you were sent the correct screen first of all, this happens ALL THE TIME to people. They are almost identical, you just have to compare the connector to the old connector. If all is well, then make sure it clicks in, and isnt flopping around when you connect. Last thing it could be is that you have a defective digitizer or you tore/damaged the ribbon upon installation. Small tears will render it dead or useless.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 273
