Repair guides and support for a wide range of small engines.
103 Questions View all
Can’t get lawn mower to start not getting fuel
I have a bad boy zero turn 27 horse! We have changed the fuel filter, fuel pump and it has fresh gas! We still can’t get fuel to pump. We have cleaned the air filter and everything. Please help
4 Comments
@ematthews1 what make and model engine does this "Bad Boy" have?
by
Briggs & Stratton model #440777
by
@ematthews1 you do not get any fuel past the pump? You checked to see if the pump works? Checked your float bowls and fuel lines? The engine runs/starts with some starting fluid?
Possible that the model number is a 44Q777? It should be followed by a dash then 4 digits a dash and 2 digits.
by
I have a Big Dog R-754 and not getting fuel to the fuel filter and it is full of fuel
by
Add a comment
1 Answer
Chosen Solution
@ematthews1 a big reason for the exact number of your model is that there maybe a fuel solenoid between the fuel bowl and the main jet. If that does not turn on you will not get any fuel. A good compete engine numbers and lots of pictures what you are working on may help to make a proper determination. Adding images to an existing question
TESTING SOLENOID
If solenoid does not click, the problem may be in equipment wiring, engine wiring harness or solenoid. To determine whether problem is with wiring or solenoid, perform the following tests in the order shown.
Test Equipment
A digital multimeter is required to test the solenoid equipment wiring.
The following tests will be performed with the meter in the V (DC volts) position
TESTING EQUIPMENT WIRING
1. With keyswitch in OFF position, disconnect equipment wiring harness connector from engine wiring harness.
2. Attach red meter test lead into equipment wiring harness connector. (side opposite raised rib)
3. Attach black test lead to a good ground
4. Turn keyswitch to ON position.
a. Meter should display battery voltage at connector. If meter does not display battery voltage, problem is with wiring harness. Check for loose or broken wire. If meter displays battery voltage, test engine wiring harness.
Fig. 31 − Checking Wiring
EQUIPMENT WIRING HARNESS CONNECTOR
TESTING ENGINE WIRING
1. With keyswitch in OFF position, re-connect equipment wiring harness to engine wiring harness and disconnect harness at solenoid.
2. Insert red meter test lead into GRAY wire in solenoid connector.
a. Meter should display battery voltage at connector. If meter does not display battery voltage, problem is with engine wiring harness. Replace. If meter displays battery voltage, problem is with solenoid. Replace solenoid.
Score 3
Add a comment
Add your answer
Ericka Donathan will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 120
All Time: 4,895
