4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1050 Questions View all
Should I fix this iPhone?
So a customer bought a brand new iPhone SE around 6 months ago in our shop.
He came in with the problem that his battery was draining really fast. I also noticed the cable doesn’t plug in smoothly. Checked with 3utools and it said 93% battery health. I decided to take a look inside, because there is a crack on the glass strip on the back of the SE and I am almost sure Apple will not repair, because of it. To my surprise when I opened it I saw what looks like repair/refurbish traces. Solder spots on places where there should not be any, Flux on the sides of the CPU cover. Test points have little dents in them what should have left when probbing. Screw hole that has been stretched out a bit. Looks like a screw was forcibly screwed in.
The problem now is that the phone is restarting itself after a few min. I noticed a filter (FL2400) is missing which is right above the battery connector and I don’t know if it was already gone or I accidently removed it while removing the battery. It is charging with 0.2A, but that could be because of the “bad”battery. The phone also powers up with 1% charge and if I plug in the cable it goes up to whatever percentage it is on.
Battery info was also false, the health is at 81% and a 1:1 copy according to my battery tester. Checked the parts and everything is said to be original in 3utools. Dates are also correct when I type in the IMEI on the apple website. I have never seen an brand new iphone with traces like this. Should I take the loss and repair it myself or just send it to Apple and let them deal with it? This is the 2nd SE I have opened so I don’t know if it
I am ordering a new dock and battery to see if that helps the problem, but I doubt it will.
1 Comment:
I put back the filter and it still powers up with 1& battery and then it goes up to 30%. Can't send it back to Apple now lol so any advice is appreciated
by
Add a comment
1 Answer
Have you tried a new battery or powered it with a PSU just to see if it will turn on? Regardless, before you do anything else I’d inform them of what you found.
2 Comments:
It didn't restart after I placed back the filter FL2400 powered by a PSU. I made a backup and it went fine. I am getting the battery and dock on monday. Think it was a combination of bad battery and missing filter that caused it. Will know more on monday
by
Put back F2400 and C2400, but I accidentally broke pin 2 on the battery connector. That together with pin 3 should be what senses the battery. I heard as long as you have it will still work because they are on the same line. The battery still says service, but that can also happen with non-apple batteries. I don't have another spare SE battery lying around. The one I bought should be pretty old because it is on 99% battery health and new ones usually start over 100%. Any advice
by
Add a comment
Add your answer
KWH will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 120
