iPhone 7 no power repair
Got a iPhone 7 no power at all. its Not detected in iTunes.
if I try boot phone on usb meter It goes straight to 0.41 on usb meter.
If I remove battery and try boot using dcps, I get 0.02 amp current draw.
No vcc main shorts. checked voltage on battery terminal with usb connected i get 3.75v so im pretty sure tristar is ok.
tryed diff battery and dock connector.
tryed diffrent tigris and removed q2101 and jumped still the same on usb meter.
1.8v always present
Vcc main 4.2v present
pp_vcc_batt 4.2v present
PP_VCC_MAIN present
PP_VCC_BATT PRESENT
PP3V0_NAND, present
PP0V9_NAND present
PP1V8 present
PP1V8_SDRAM present
PP3V0_TRISTAR_ANT_PROX present
5V0_usb 4.73v present
PP_CPU 0.75V
PP_VAR_SOC .804
Any fellow techs help very much appreciated.
4 Comments
Did you break or snap a wire or charger tell me more in the comments steven Smith (:
by George
I am facing the same issue :)
by Gomes
@Steven smith I'd like to know the answer to this as well? Did the car charger cause the problem? and did you find out how to fix it
by Uber Babsen
I got 2 of these this week, a regular 7 and a 7 plus. Exact symptoms. I did try replacing tristar and first time I tried to power it on the bench it seemed like it was booting based off of power draw from the power supply but after turning off and hooking a screen up to it, it went back to the previous state.
by joel rakich
