Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
Why is my tv turning off and on randomly?
i have a samsung UN55JS9000FXZA it works perfect but randomly it will cutt of and power back on and will continue to work it does this sometimes within 30 minutes other times within hours im not sure if its a power board or main board maybe? hope to hear from you soon thank you
Add a comment
Most Helpful Answer
@omputers
going by your description alone my number one suspect would be the power board. Let us know if your TV shuts completely off or if it just the screen that turns black. Also, try multiple different input sources (one at a time)and see if it still shuts off. Something like a bad cable box etc. can cause this as well. Remove the back from your TV and check all the boards. Check for damaged looking components etc. Post some images of your boards with your question so that we can see what you see. Adding images to an existing question
Score 1
1 Comment:
all components look fine and its something that happens randomly sometimes runs for hours no problem than it will happen, other times it will do it within 20 minutes looks like if i was to turn off and on but i did not do anything,I reset the settings its a smart tv so i use the smarthub to watch netflix to see if its the box were hdmi connects to but that is not the issue
by
Add a comment
Have you checked to make sure the power cable is fully plugged in sometimes the cable can be slightly unplugged and work for a period of time than shut off.
Add a comment
Check the connection very well. If the power ups and down then this might happen.
Add a comment
Add your answer
Wilfredo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,367
