Repair guides and support for cars and SUVs manufactured by the Mitsubishi Motors Corporation.
111 Questions View all
Mitsubishi Endeavor Driver side window controls won’t work
Hey i have a Mitsubishi Endeavor 2006. The driver side window switch won’t open or close any of the car windows. The switches on every other door can still open their respective windows. I bought a new switch and installed It but that didn’t fix the problem. I’m thinking It could potentially be the wire connected to the switch. I wanted to see if anyone thinks this could be the issue or if it’s something else. Also how to go about fixing It. Thank you.
Add a comment
1 Answer
The ground wire going from the door to the main body is loose or broken.
To much to go through to replace specific wire, you could run any new wire from door to body & see if its good.
Hold down the lock button on the driver & passenger door at same time, roll down driver window. All 3 buttons at once.
Add a comment
Add your answer
mlise785 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 18
All Time: 227
