15% Off Selected iFixit Tools — Limited Time
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
remove cover with screen protector
Can I remove the phone cover with isclack or suction cup without removing the screen protector glass first?
Score 1
Add a comment
Chosen Solution
short answer , yep just did it
Add a comment
Most Helpful Answer
if you are carefull enough then it is possible, when you have lift the front put some thin knife in the gape between front and housing at the bottom.
Score 2
Add a comment
My preferred method would be to use the iSclack to get in-between the frame and the screen just enough to get a pick under the screen. Then use the pick to loosen the clips. Works every time even with screen protectors.
Add a comment
Add your answer
Patrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 121
