15% Off Selected iFixit Tools — Limited Time
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Screen wont sit flush
Hello. I changed the charging port and battery and now when i put the screen back on, in the down right corner it doesnt sit flush. Its raised a bit. Please help
Add a comment
Chosen Solution
This is usually caused by how the screen flex cables are aligned. Take a look at the flex coming from the screen and notice that there is a silvery “chip” on the flex. If it isn’t aligned properly, it will impede the way the screen sits on the housing.
Score 3
3 Comments:
Where is the silvery chip ? I cant find it. Could you send me a photo of it please ?
by
oh, i know what chip. It seems that the chip from my replacement screen is a bit bigger than the one on the original one. What should i do with it ?
by
The arrow of the "Start Guide" practically points to it :>). Sometimes it just needs to be moved over a little bit until it rests in the opposite "hole" properly.
by
Add a comment
Did you use this because without it, it can cause it to pop up a little. iPhone 7 Display Assembly Adhesive
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 7. Image
Product
7 Comments:
No I didnt but i dont think its the solution. I noticed that the silvery chip on the flex cable is a bit larger than the one on the original screen. I think it doesnt fit in because its too big. What should I do about it ?
by
Where did you get the screen from ifixit?
by
Ok if you didn't get it from here then get this. iPhone 7 Screen iPhone 7 Display Assembly Adhesive
by
OK, thanks :D
by
Keep me updated on how it goes.
by
Show 2 more comments
Add a comment
Add your answer
Martin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 205
