Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6S screen went black and came back but battery drains very fast
So i changed Iphone 6s battery for brand new, original apple battery. After that it worked for few hours and screen went black while the phone was still working. 2 days later screen came back like normal but now battery drains very fast.(3 times fully charged during day without usage).
How can i fix it,as battery is new and this is all strange to me?
Add a comment
1 Answer
Chosen Solution
Several things can cause Battery Drain issues. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from one of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
1.     It could be a bad replacement battery; there are lots of cheap batteries on the market.
·      Try replacing with a known-good battery or order a good one from here.
2.     You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
·      Fully charge the battery first.
·      Disconnect the battery and then disconnect one modular component at a time to see if you can determine which part is bad. I would start with the front camera flex, then the rear camera, then home button.
3.     If that doesn’t make a difference, then you should try to disconnect the screen to see if it’s the screen or the logic board
·      Disconnect the battery, then disconnect the flexes for the screen assembly, buttons and cameras, leaving only the Lightning Dock connected to the logic board (follow these guides). When you are done, re-connect the battery.
·      Go back after an hour or more and test the condition of the battery. You will need to download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition.
·      It could also be the Lightning port so you could try the same test as above but with the Lightning port disconnected once the battery is charged (connect it back to test the condition of the battery).
4.     You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
Score 3
1 Comment:
thank you very much,i will try it,i assume its screen or faulty battery but i must check it out
by
Add a comment
Add your answer
Dusan Todorovic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 412
