Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 Questions View all
Freezer not cold enough
Hi, I have GE DSHS6VGBBCSS, on the control display freezer is -9 and the fridge is 37, ice cream is melting on the freezer, fridge temp seems okay, I replaced the mother board, 2 thermoster on the freezer and the thermostat but did not fix the problem. The display control is working fine. Please help
Add a comment
1 Answer
Chosen Solution
Hi @uginel ,
-9 deg F should definitely freeze ice cream as the normal temp for a freezer is approx. 0 deg F.
Is the ice maker producing ice OK?
Is the compressor running continually trying to drive down the temperature to the set temperature? Check first thing in the a.m. if the compressor has stopped (it may not have just the better time to check) as the unit has had all night to get the temp down to the set temp without a door being opened.
Try placing an appropriate thermometer at various places in the freezer to check that the temp shown by the display is correct
Check the door seals of the freezer door to make sure that they're OK.
Place a sheet of paper between the freezer door and the freezer cabinet and try to pull it out when the door is closed. Try this at various points around the door. It should pull out with a bit of effort but not come out too easily or even fall out, which indicates a poor seal
Score 2
Add a comment
Add your answer
ugin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 144
