Nintendo Switch not turning on
On a USB Ammeter it displays 0.46A and constantly stays there.
Opened up device and found battery was pretty much flat. Charged it up around 3.7-4.2V and attempted to turn it on with the battery connected once the battery was charged up externally at that voltage.
It still did not turn on and charger still reports 0.46A. No signs of liquid damage on board as inspected under microscope.
I would suspect charging chip but isn’t it supposed to turn on with a charged battery if that was the case and not charge?
6 Comments
Unfortunately, this is one problem I've never found the fix for and I don't know of anyone that has. I don't think there is a fix for it at this point.
by TronicsFix
I noticed that BQ24913 (Lower bottom left pins) and the cap next to it becomes shorted to ground when I plug the battery in so I may replace that chip and see how that goes.
by Ben
Did you use a 3rd party dock? I think that that still happens.
by TheYootz Media Group
I'm doing this for a client so I would have to ask them whether they did or not.
by Ben
Did you ever get your Switch working? I am experiencing something similar with mine. It was working fine, but all of a sudden now it will not power up, when I put it in the dock, the dock green light flickers on for a second and then nothing. Battery is 4.2V, power switch is getting power, i have not found any capacitors shorting out, and there is no corrosion, heat issues, etc... Really stumped with this one.
by Joseph Stratton
Show 1 more comment
