Damaged screen is worth fixing?
TV screen accidentally got hit. Is worth fixing, or just replaceTV??
TV is vizio tv 65inch
P65-F1
P65-F1
Hi,
You could try searching online using the panel number (found on the back of the LCD screen, to see if you can locate a replacement or not.
If you do happen to find one, you’ll find that usually they cost nearly as much as a new TV.
An option to consider is advertising your TV for sale as broken screen - good for parts to try and recoup some of the cost towards a new TV.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 734
1 Comment
Emmanuel--just curious to see what you ended up doing and/or if you found a solution? My screen is doing vertical banding (black and white) intermittently.
by bluemaimind
