4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Bottom pentalobe screw spinning in hole
Hi guys,
I replaced the screen on an iPhone SE I acquired cheap but am experiencing some strange behaviour with ghost touches and missed inputs. To fix this I will try cleaning the contacts and or trying another display but on trying to open the device one pentalobe screw comes out fine but the other just spins in the hole at the bottom of the device. There is another question on here describing similar behaviour on an iPhone 4 but my experience differs as I am using the official screwdriver from my ifixit kit and the handle of my screw driver has not come loose with the shaft and screw remaining stationary as was suggested on that post and the screw head is in perfect condition with no stripping as was also mentioned in the other post. The screw spins perfectly just with no backing off.
I’m baffled guys i have tried the rubber band method even though the screw is not stripped and different screw drivers any help would be greatly appreciated.
Thanks,
Callum
Add a comment
1 Answer
Most Helpful Answer
Screws just spinning generally mean the metal posts have broken off the screen. Or back cover for your iPhone 4. Sometimes lifting up the bottom of the screen a tiny bit with prying allows you to remove the screw that just spins.
Score 1
1 Comment:
If lifting up on the screen does not make the screw come out then I would see if you can just pop the screen out from the bottom. We run into this some times when we are doing repairs. It's also sometimes possible to get the screw to attach to the screwdriver it is's magnetized and pull it out.
by
Add a comment
Add your answer
Callum Cooper will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 252
